where'd you get the mtl ? a specialty supplier of polymer-modified b-top patch OR the apron/vest store ? from what i can find, here its h/d,,, we'd NEVER use that stuff for our clients.
how deep was/is the sawcut ? it should have been thru both layers of b-top,,, streets are built w/coarse b-top mtl on top of a compacted granular base,,, a smaller mix is then paved on top of it,,, YOUR main issue is the mtl meeting whatever the town's specs are for the existing street,,, usually they'd spec a dot approved mix + thickness + compaction density - you can't satisfy those rqmts :no: talk nice to the town's pe & street maint chief - hopefully they'll take pity on you :yes: the pe's position is probably NOT an elected office - perhaps the chief's is - you decide what to do :laughing:
i doubt the town ' owns ' the 1st 10' HOWEVER they do have an easement if they widen the street/upgrade water service lines/etc,,, you're paying the taxes on that 10' tho
to answer zzzzzzzzzzzzz, its called ' tack coat ' - a cutback asphalt
