1 - 10 of 10 Posts
Hi, I´m new here and i have an question about my snowblower
I have an Ariens ST824 tek-8hp. I´ve cleaned the carb 3 times now, changed the spark plug, fresh fuel and checked the fuel line, everything seems okey. But it will only start if i put the throttle on low with or without choke. Then it will run for a bit, but i won´t run smooth. If i try to give a little bit more throttle it stops and brigt white smoke comes out of the muffler.
Any suggestions?
I´ve tried to clean out all the jets with a compressor, still wont run like its supposed to. I can get it to start like before on no throttle, and it will run for a second or two on full throttle, but it only ignites once a second it seems. Dark grey/black smoke comes out of the muffler on full throttle.
Any more suggestions??
I´ve tried to clean out all the jets with a compressor, still wont run like its supposed to. I can get it to start like before on no throttle, and it will run for a second or two on full throttle, but it only ignites once a second it seems. Dark grey/black smoke comes out of the muffler on full throttle. :(
Master General ReEngineer
Donno, but it sounds like it's Still got a Carb problem....
Black smoke says it's flooding out....
1 - 10 of 10 Posts
