My first soldered pipes after about 10 practice joints. I deburred, sanded and cleaned the pipes with steel wool, used brush attached to drill on fittings, and wiped all down with clean cloth. Applied flux to inside fittings and pipes, then heated from bottom and applied solder to top and let it flow into the joints.
I know some are ugly, but do I need to redo any of them? If so, what is the process to redo?
Thanks!
Thanks!
