I just moved into a home with most of its windows replaced, however they left the finishing to me -- the new owner. So there are no exterior or interior trims.
..the new Andersen windows replaced bigger windows, so whoever installed these had to build up the surround (with 2x4's, drywall, insulation, exterior siding, etc) so that the new (smaller) windows would fit.
The problem is it appears that they installed the windows AFTER they built up the exterior. So the exterior siding of the house (boarding) is underneath the metal casing of the window, ie. you can see the nail heads.
My question is, isn't this a wrong way to install windows? Do I have to redo all these installs (over 10)? Or is this an ok lazy technique of installation -- and I should just finish the trim?
Also on the inside the jamb extensions are like ~1 inch too short as a result of the window depth being pushed out by the depth of the siding.
Thanks in advance!
Link to photos:
http://picasaweb.google.com/bogamilsan/HouseWindows?authkey=Gv1sRgCJ60lczRz_yEtAE&feat=directlink
Thanks in advance!
Link to photos:
