I installed a new circuit in my house and wired it to a 15 amp arc fault circuit breaker. I just wired the first plug only and tested it. The Tester lights show its wired properly but when I put any load on it the breaker trips. The Romax is about 40 ft from the circuit. I wired it with 14/2 wire. Is this indicating I have an issue with the wire going to the breaker I would figure if there was a short in this wire that it would trip the circuit immediately. could I installed the breaker wrong? it has a test switch on it which appears to work? I already have the drywall up so would be in trouble to rewire this
