I have searched quite a bit on this and have come up empty. Hope someone here can help.
We are finishing a basement and we have wired the bedroom and bathroom lights on the same circuit. Bedroom lights need AFCI and bathroom lights need a GFCI if they are above a bath or shower, which they are in our case. Question is what type of breaker do I use? It is my understanding that AFCI breakers contain some GFCI protection (5 mA), but are not as sensitive as true GFCI breakers.
What is the right way to handle this? Do I need to split the circuits? I hope not as breaker slots are running out.
JB.,Install the arc fault breaker, the use a dead front gfci to feed the light switch in the bath room.
Is it a local code to require the lights to be gfci protected?
The dead front GFCI look like this.,I am installing 12v recessed low voltage cans in the cieling. One of them is above the shower enclosure. The ceiling height is about 7' 4".
Ok that something I don't useally see very often but a good choice is 12 volt recessed but make sure you have shower trim on that one due the height is kinda in gray area.
I do not know specifically if the code requires the GFCI for that light, but the electrician we had wire the new service up said that over a bath or shower needed one.
If your luminaire installment sheet call to use the GFCI then you have to use it but if they say noting about it you can let it go unless it is admended in local code requirement.
I did not know about dead front GFCI. I could certainly use one of those, but with heat/vent and lights, I would end up with a 4 gang box for a 60 sq ft bathroom.
It kinda common item with dead front GFCI devices however., there is other issue it will come up is your heater/ vent / light that will useally required it own circuit.
I will post the photo what it look like in a bit.
In looking at this, it seems odd to me that there would not be a breaker that could handle both, as I am sure many would not mind paying for it to reduce switchplate clutter and to provide additional safety.
I am not well verised with this one but I think you may get away from using the GFCI but take this info with grain of salt until you get couple guys whom they will know little more on Americian code than I do and the other issue is the remote transfomer where that is located ? ( you may end up need a way to get into it.)There is nothing in the spec sheet for the fixture that mentions GFCI that I can find.
These are the lights.
The lights use a remote low voltage transformer, so the voltage at the light is only 12V. Similar to what is used outdoor garden lights. Not sure if that matters though.
