I will be using some sealer over my aggregate driveway.Is a wide roller the best technique for applying it (clean and dry of coarse),or can i use a spray type application . Also is 1 good coat best or 2 light coats(dry time in between)?
Sprays work best for pros with the proper equipment and product
I'm assuming your product is meant to be dumped out and smoothed over with a brush-type or squeegee type tool
As it could vary depending on product, the product itself should have the information you want right there on the can somewhere
Or post up the product, maybe someone here's used it before
