My air conditioner kept tripping the breaker today. Maintenance came out and we went through all the wiring. The problem happened to be the wiring had melted 3 inches inside the outer wall before the disconnect. My question is the wiring in the wall is only 14 gauge does this meet code in Texas? I dont have the specifics of the air conditioner but size wise my apartment is 829sq feet. The AC unit is 220v on 2 pole 20amp breaker. The length from the box to the outside wall is 40 to 50 feet
Coming out of the wall to the ac unit the wiring changes to 12 or 10 gauge. I know it would be much better had they used a heavier gauge wire but Im most interested if it is up to code because if not I will make they re-run the wire
I am afraid my apartment will burn down please advise. Thank you for your help!
Camden
Camden
