1 - 7 of 7 Posts
Not sure if this is the right section (mods-move it if you think it fits better elsewhere), but i need some info.
I recently picked up a 3 foot commercial flat cooking griddle on a stainless steel table at an auction for cheap ($76). It's stainless, 5/8 inch plate. It was electric at one time (didn't work) but i removed all the heating elements and controls and am replacing them with propane burners, in order to make the unit portable. I have a pretty good idea how i'm gonna locate the controls and such, but i'm wondering how close to the bottom of the plate i need to position the propane burners in order to get the best even heat. I've Googled till i'm cross-eyed and can't seem to locate any info. has anyone done this, or have a griddle they could look at and give me an idea? If not, i guess i'll just make them adjustable till i find the best location before i lock them down. It's a winter project, but i'm ready to get started on it now and was hoping i could get some info here. I finally got all the baked on grease off of everything (what a job!) and now am ready to start assembly. The unit is probably 20 years old or more but in great shape once i got all the crud off. I can post pix later today if it helps, but i'm just looking for a starting point to locate the burners.
Retired Moderator
Those typically have two long burners under them (rather like the burners in a boiler)
What kind and shape of burner do you have? The out put would have a great deal to do with the distance below the steel plate.
If there is a commercial kitchen fabricator in your area---they often have a 'junk yard' where you might find the burners and controls you would need. Beware that these folks tend to think that the junk is made of gold.---Mike---
Discussion Starter #3 (Edited)
Oh'Mike
as always, thanks for the reply:thumbsup:
I have not bought burners yet. I had thought about the long tube burners and also the H shaped burners. (i haven't bought either yet-but both are available locally). I was sort of leaning towards the H shaped burners, because they would give me more "zone" heat control and i could regulate the heat better for different temps on different areas of the griddle, since they have a wider flame pattern. Can you think of any reason why i shouldn't go with the H shape?
I haven't been able to find any info locally-----yet, but i'm still looking.
I was hoping maybe someone here had done what i'm thinking of doing.
thanks again for replying!
Retired Moderator
The burners you are thinking of are the ones typically used for a BBQ grill?
I think that should work----
Even heat is the whole object---If you could cannibalize a high end grill with multiple controls the job could be done quickly.
Start trying to convince your friends that they need a new grill!!
Discussion Starter #5
Mike,
yep, those are the ones.
I'm thinkin that may be the best and least expensive (OK---cheapest) route to go.:laughing:
I'm thinking of mounting them about 3 inches below the griddle plate would work, so when turned to high-- the flame tip would be right below the bottom of the plate. I guess i'm just looking for suggestions, but does this sound logical to you?
thanks again!
Retired Moderator
Sounds like the way I'd try it.
If you could play with the elevation before fixing it permanently--all the better.
I'd be looking for an old grill to cannibalize for the controls.
1 - 7 of 7 Posts
