I have a 10'x10' kitchen I want to remodel. The entry off the living room is through an opening in a load bearing wall. The far wall is an exterior wall. You would think that there would be joists spanning this 10' from load bearing wall to exterior wall, BUT, there is an "extra" beam 4' from, and parallel to, the entry wall. The joists from the living room extend over the entry wall beam to about a foot past this extra beam on the window side. the joists coming from the window wall are about 8' long and end about 2 feet past this extra beam on the entry side. I need to get rid of this extra beam for the kitchen renovation. My original plan was to try to sister the joists coming from the window wall with full length joists which would span to the entry wall beam. But I just wanted to ask...since I have about 2 feet of joist overlap, is there any splice plate product which I could simply anchor to and through this overlap, to get both joists to act as one? I am pretty sure the physics don't allow for that kind of thing, but I thought i would ask before I went the sister route. Any other suggestions are very welcome! Thanks.
