Setup:
Pressurized irrigation system. 1 1/2" service line, gravity fed, ~20psi.
I added a 1/2 hp booster pump and reduced the line to 1 1/4". At the end of the 300' "main line" (which is 1 1/4") I measured the flow:
~15 gpm
I then turned on the 1/2 hp booster pump and measured the flow
~20 gpm
Question: What do you think the pressure is if I restrict the output to 13gpm (which is the size of the largest sprinkler zone I am planning to install). I would like to see a minimum of 45psi -- but since I am a mere mathematician and not too well versed in Bernoulli's Principle I figured I throw it out to the wise engineers.
~15 gpm
~20 gpm
