I have two questions if you don't mind...
Is there any particular codes that says you have to wires in the correct through hole in a junction box according to it's light switch? meaning...say i have a three gang junction box for light switches. I have a motion sensor light switch on the far right, however the source and wires to the light is all the way to the left through holes. Is it against code to have wires coming in through the left holes and wired to a switch on the far right gang slot?
Also can you have to 12/3 and 12/2 romex cables coming in through the same through holes say if you run out of holes?
Second question is...can you run alarm wire alongside AC romes 12/2 cables?
