looks fine, but I can see the teflon tape is wrapped in the wrong direction.
Hmm.... A friend of mine.... seems we have heard that one before.:thumbup:Then assuming you have no leaks...and the valve is at the correct depth..you should be good to go. A friend did something similar said he leak tested...when the water came on it also came out. He had to hack up his new work...not a pretty sight....
Yeah, if at all!Good grief, you're testing it to death! lol A 30 minute test is all that an inspector requires.
