20878, Mr. Federer, the world number 3. Do you play tennis?i have the same issue. where in MD are you?
There are probably no perfect solutions to this problem - at least not without spending some serious bucks. But here's what I'd suggest trying.I bought a small 3-level town home (basement, level 1 and level 2), with central AC. The basement is pretty cool these days even without AC. The top floor is kinda warm even with AC on. I heard that hot hair goes up and cold air goes down, and this has to be the cause. Just wonder if any of you guys out there has any good tip to cool down the top floor. Does it help to set up a powerful fan on the top floor to force the air circulate across all 3 levels? Please give me your tips, thanks.
cool. i am 20902. I am the Federer:thumbup: Do you play?20878, Mr. Federer, the world number 3. Do you play tennis?
you are right ducts would be best, but how feasible is that? I imagine the house is already covered in drywall/plaster and requires major demo and rebuild if you are connecting ducts from from 3rd to basement level...Thermally, the best way to minimize temperature stratification is to insulate and air seal the house more, which may or may not be practical. You are correct in stating that warm air, being less dense than cold air, will rise (heat does NOT; heat goes to cold. Warmer AIR rises, just like warmer water, over most temperature ranges, rises). Were this my problem, I would try to pump the warmer air back down to the basement via ducts instead of pushing it through other air and mixing it. I am certain ducts would be far more efficient.... though maybe not easy to install.
Dunno. The cat hasn't asked us over for dinner yet. I'd sure try to sneak through closets, utility rooms, suspended ceilings, etc.... but how feasible is that?
Yes, I do. I don't think you will win this French Open. Nole will.cool. i am 20902. I am the Federer:thumbup: Do you play?
Where do you usually hit? I see you hopped on the Nole wagon as well. Long live the Fed! I don't see DelPotro taking Nole out.Yes, I do. I don't think you will win this French Open. Nole will.
That's kind of whats in my house. lots of ducting in the closet. so far no use. but they were probably badly installed since it was a DIY thingDunno. The cat hasn't asked us over for dinner yet. I'd sure try to sneak through closets, utility rooms, suspended ceilings, etc.
I hit in 20878 area. I was hoping Del Potro could defeat Nole, but he had too many unforced errors.Where do you usually hit? I see you hopped on the Nole wagon as well. Long live the Fed! I don't see DelPotro taking Nole out.
don't usually hit up in gburg....where is a nice court to go to?I hit in 20878 area. I was hoping Del Potro could defeat Nole, but he had too many unforced errors.
