Called in repair man, he said my freon was low again, could refill or do leak check and refill.. blah blah blah, or install new unit. Unit is 15ish years old so thought probably better to get new one. Last year they refilled and put in some stop leak stuff.
Since replacing the thing is a kick in the shorts budget wise, I started looking to see if it really needed replacing. I found my run capacitor was too small, I changed it and still no joy ( there's a thread from last week on this). So got three estimates.. Today I went out to take the capacitor off since it was new.. and poked around a bit more and noticed a lot of oil around one of the lines (the bigger line- so my guess is low pressure line?). So I guess leak, and get some soapy water and slap it around.. well it's leaking ever so little from the schraeder valve. But I guess over a year that will add up. I'd say that any detectable leak is too big, is that correct?
Waiting on a call back from the company that came out to see if they will make it right.. seems like an OBVIOUS thing for an HVAC tech to notice.
