A tenant called yesterday and said that there was a leak in the water heater, located in the garage.
I asked him to send me pictures, and from the pictures I saw it was a leak from the tank.
This kind of a leak can't be repaired, so I loaded a replacement WH into the van, got there at 3pm. Emptying the WH took longer than expected, due to minerals blocking the drain bibb, so I used a wire 2 or 3 times, to free the water passage out.
Once it was empty, it took me about 90 minutes to complete, with new copper water supply flexes, double check, fill up, turn the gas back on, light the pilot, and fire the burner. Tenant had hot water for a shower in 20 minutes.
A new 40 gallon natural gas WH goes for over $700 now (tax incl). The one I used had a minor a dent that I found at Lowe's earlier this year for $300.
Now I have to locate another one like it. With so many homes, I don't wait for the last minute to find a WH, unless I have none in stock.
This is the third WH I replaced this year.
" Your tenant is your customer - treat him like one ".
