We're preparing to tile our shower/tub surround. I'll be removing existing cultured marble wall panels and removing the existing lathboard and plaster to a height of 5 feet above the tub. The plaster walls are about 3/4 inch or slightly more in thickness. I can buy cement board in 5/8 thickness. I'm planning to lay felt building paper over the bare studs and shim them with carboard drywall shims to match the plaster thickness. I'm thinking the shims will go under the felt paper and should do the job. Do you agree? Would 1/4 inch lattice under 1/2 inch cement board be more reliable?
At the cement board/cement board joints I want to finish with mesh tape and thinset and where the cement board meets existing plaster the plan is to finish the joint with mesh tape and drywall setting compound which I've been told will also support tile. Any suggestions?
Thank you for sharing your experience and expertise.
