Hi -
Remodeling the bathroom. Just got my bathroom demo down to the subfloor (well most of it - left the toilet in so far). The bathroom slopes away from the door, about 3/8" from the door down to the opposite wall where the toilet sits (8 feet). It's also not flat - there's a bit of waviness. The bathtub alcove is parallel to the slope, with the drain side being about 1/4" lower than the non-drain side.
The bathtub leveling will be easy enough to get past since I'm putting in an acrylic tub and bedding it in mortar, which will allow me to squish it in there perfectly level.
The question is the rest of the bathroom and how it relates to the tub. If I put the tub in there level, the apron will be 1/4" off the floor at the drain side. Do I put down 1/4" backer in the rest of the room, then pour SLU over that to get it flat and level, and just mask of the bottom of the tub to keep the SLU off of it? Or would it be better to pour SLU over the entire wood subfloor to get the whole room flat and level, then tub and tile over that?
Wood subfloor is 3/4" T&G over 2x10 joists. Bathroom is an irregular shape, covering around 45 sq ft total. The bathroom is centered over a load bearing wall beneath it so span is not a concern.
