Hi All,
I'm remodeling one of my bathrooms, and currently drawing up my detailed plan of work. Demolition at least is complete. I've seen a number of these threads, but they have varying levels of detail, and often have slightly different goals than me.
First, a description of the project. Installing a new tub, tiled surround up to ceiling (well, crown), tiled floor. Bath surround will be water proofed with redgard. On the non-shower walls will be beadboard up to 2/3 height. There will be crown around all walls (including bath/shower area). IKEA vanity and sinks, which require very particular plumbing. Replacing drywall and insulation on outer wall. I pulled down popcorn ceiling, so the ceiling needs patching and painting.
I figured out the order below based on minimizing both the work and risk of damage and/or paint splatter on the tiled floor. The one confusing bit was whether to do the trim before or after the floor. Doing it before means less chance of damage, but makes the floor install harder. Anyway, here goes, let me know if you see any problems:
Extend toilet supply pipe, install valve
Cut back sink supply pipes, install valves
Cut back sink waste pipes, install 90s to accommodate IKEA P-traps
Rough electrical
Ceiling exhaust fan
Skim/patch ceiling
Paint ceiling
Remove/replace wall insulation
Tub
Insulation around tub
Bath surround backer boards
Build inset bath shelves
Drywall (new) and drywall repairs
Tape backer board seams, skim with thinset, transition to drywall
Apply Redgard
Crown
Paint crown
Tile bath surround
Paint walls
Floor backer boards
Floor tile
New toilet flange
Door casing
Window casing
Beadboard
Beadboard cap
Paint beadboard/cap/window frame
Baseboard
Paint baseboard
Shower head
Bath handle
Bath faucet
Toilet
Vanity mirrors
Vanity lighting
Vanities
Sinks
Sink faucets
Towel bars and hooks
Closet shelving
Paint touch ups
Caulk
Rough electrical
Ceiling exhaust fan
Skim/patch ceiling
Paint ceiling
Tub
Apply Redgard
Crown
Paint crown
Tile bath surround
Paint walls
Floor backer boards
Floor tile
New toilet flange
Door casing
Window casing
Beadboard
Beadboard cap
Baseboard
Paint baseboard
Shower head
Bath handle
Bath faucet
Toilet
Vanity mirrors
Vanity lighting
Vanities
Sinks
Sink faucets
Closet shelving
Paint touch ups
Caulk
