I am trying to clean up after a nightmare job by a local handyman. After noticing the rubber washer between the outer drain and the tub, not the shoe and the tub, I unscrewed the outer drain and attempted to place the washer between the shoe and the tub.
The shoe is slightly angled and very close to the tub. When I put the washer in place, it is very tight at the drain side, and slightly loose on the opposite side. Loose enough to move around.
I suspect this will not hold or create a seal and that the drain will have to be redone. I have two questions:
1). Is there a way to fix this without removing the entire drain assembly?
2). My wife told me he requested 5 small tubes of epoxy when connecting the plastic drain he cut when replacing the bathtub. I should be worried, shouldn't I?
Thanks for your help.
