What voltage will you be using?Just wondering if a 14.4A pump could run off 12-2 wire 200' from breaker? Not sure the formula or whether the drop puts the load over the 18A limit?
Same question here, what voltage?Just wondering if a 14.4A pump could run off 12-2 wire 200' from breaker? Not sure the formula or whether the drop puts the load over the 18A limit?
He's in Ontario.3.7% voltage drop or 7.7v.
14A @ 208v 3 phase.
it's within excepted limits.
Whats the accepted limits Ontario ?He's in Ontario.
For a 120V load you would only see about a 9V drop when running, which is perfectly fine.
But you'd probably see a 40-50 volt drop while starting, which is very significant. If the pump has a centrifugal switch it may never even get up to running speed.
% is the same. But what is the voltage? I don't think he has 3phase 208.Whats the accepted limits Ontario ?
