Hi all -
My water heater has a T off from the hot line that runs though a pressure relief valve, and eventually exiting outside on my patio. I'm not sure why it's there but maybe the original builder (about 22 years ago) did that because there's no drain in case the heater's TPR valve triggers (I keep a bucket under the heater's TPR valve pipe but it's never opened).
Anyway, that ~22 year old, secondary pressure relief valve opened and won't close, and I've got a steady hot water loss through it of about a gallon per 10 minutes. This valve is adjustable but when I took pressure off the system and tried to adjust it, the valve itself started leaking (great, now I've got TWO leaks).
So I'm just planning to cut that T out and remove all the pipe to/through that secondary pressure relief valve, and replace the T with a straight-line connector on the main hot water pipe.
Here's the question: Normally if replacing the WH I'd shut everything down, open taps upstairs, drain the tank and the house. But what if I let the tank cool, shut off the water supply and blow off pressure (if any) using the tank's TPR, then cut into the hot pipe to remove that T fixture without first draining the WH tank and whole house? In a 2 story, 4 bathroom house with the water heater in the basement, how much water would come crashing down on me?
Is it crazy/stupid to even attempt this?
Many thanks in advance. The only reason I thought of this is the last time I got a lot of air in the system, we had pretty bad pipe squeal for months.
