Ameristar HP4A3630 3Ton heat pump
I Shorted out my furnace leads while putting the breaker panel back on, unit was running in heat mode. Now the compressor won't kick on and my defrost board is flashing three times which means "LOW PRESSURE CUT-OFF SWITCH IS OPEN" if I short those leads out I can get the compressor and fan to kick on, if I flip my defrost to manual I can get it to defrost by shorting out the same leads.
Tried a power cycle but didn't do anything. I have 24v in IIRC (it was dark).
I am leaning towards a bad low pressure switch, bad board, or actual low pressure (had a leak last year and had no charge but it never cut it off from running).
Could it be anything else?
I was thinking contactor but since it fired up after having the the pins shorted i threw that out.
I have a single pole contactor with a new board as seen on page 16 here:
http://tranepennohio.com/secure/techdocs/December 2014 3T2.pdf
