No a tub is not a tub. Based on what I saw at HD it appears to be a good tub. American Standard is a leading brand of bath fixtures. The better the quality the thicker the steel is, as well as the porcelain. Your better steel tubs will also have a thin pad glued to the sides and bottom of it for heat retention and noise reduction. As said, just from the site it looks like a good tub. And by the way; If you're going to replace the toilet DON'T buy a cheap one. Come back and ask which one to buy. Good luck.
