American Standard Freedom 90 VS furnace (city natural gas supply)
model AUY100R9V4V0
SN N411SX47G
Furnace has a problem with all burners lighting. When call for heat is presented, ECM motor blows properly, igniter turns on & glows bright orange, gas control valve opens, and flame starts at burner next to igniter. However, the flame does not always travel to burners farther down the line, so the flame sensor does it's job and shuts the gas valve off. If all burners don't light after 3 tries, the control board does it's job and shuts down the ingition process (3 blink code displayed). I have not found any blockages in burner passages. When all burners light, furnace works properly, but I have to cycle power to reset the ignition circuit at least twice a day. Flame sensor has been cleaned and appears to work properly, and both overtemp sensors are at 0 ohms (closed). No other error blink codes are displayed, so I'm assuming the 2 pressure sensors are also OK. I suspect a problem with the gas control valve. What else might cause this burner issue? Is there any way to test the gas control valve ? Can the control valve be adjusted/repaired, or must it be replaced? Any ideas greatly appreciated.
model AUY100R9V4V0
SN N411SX47G
