1 - 9 of 9 Posts
Hi everyone,
In the middle of residing a house, decided to pull down the gutters to repaint them so final product looks finished.
Went down to the depot and picked up aluminum primer spray paint, cleaned the gutters and sprayed on the primer (2 coats). Then I I sprayed on white enamel spray paint the next day (2 coats)
Now that the paint has dried I am seeing some spots that look shinny and dull spots. I gave it 2 coats of spray paint, not sure what is happening. Thought this would be pretty easy job. I can see the dull spots and certain angles.
I know with car paint you have to wet sand etc but didn't think this would be the case with gutters.
Thoughts?
No not at all, gutters only are faded after of years of being installed and in the elements.
Used almost entire can on a 23 ft piece. Wondering if I should just get a can and paint them with a brush now.
Discussion Starter · #9 ·
Might go to the store and pick up a small can of paint based on what usability being said. Thought with 1 can I could cover 1 gutter, guess I'm not putting down enough paint. Went with the cans so I would have smooth coat. I could also use my airless sprayer but the winter is here and cleaning that up outside isn't fun.
Thanks everyone.
1 - 9 of 9 Posts
