1 - 9 of 9 Posts
How should the existing floor be prepared before this tile is laid? More specifically, is it OK to install this flooring over a high-quality "linoleum" still covered with dirty glue left behind from the peel-and-stick tile that has just been removed. Some balls of glue are the size of double-bubble chewing-gum. (Sorry, I can't remember that correct name of the "linoleum"; just that that it is seamless and was sold with a very good warranty)
Now that I think of it I used the same product in my garage and laundry room. For my laundry room I scraped up the old linoleum and made sure there were no balls of glue or grit whenI laid the new floor. I believe this flooring product is a floating floor, right?
MJ, Yes, it comes with pre-glued edges that overlap creating a floating floor.
Yup. Same product. I've had it in my Garage for two years now and no problems. I believe this product can be laid directly over existing linoleum floors with no problems as long as there is no lifting on the old floor.
Do a careful layout so you don't run into any problems and once you stick that edge you have about 15 minutes and then it's permanent.
Discussion Starter · #8 ·
MJ The flooring is already installed and looks terrific in the kitchen and laundry room. But we ran into a problem in the bathroom - preparing the sub-floor. The contractor wanted to add another $85 to the quote to remove the old, peal-and-stick tiles which had not stood up to the moisture in the bathroom. So I took up these old tiles myself. Underneath was heavy, dirty glue. I soaked the floor in TSP for 3/4 of an hour and then started scraping. I spend several hours of hard work and made progress but was far from done when I gave up for the evening. Next day the workers came and assured me that they could lay the new acrylic tile, Allure Sierra, directly over the sticky mess. I forgot to tell them about the TSP which I hadn't rinsed!! Within 24 hours white powder appeared in the seams in quite a few places. Two months later, the powder is almost negligible, but I'm still unable to find out if the seams and under-side of the new tiles are most likely permanently damaged. Should I accept the flooring as is? Or work out a deal with the contractor to re-do the bathroom floor. I'm not trying to shirk my contribution to the problem
This product is fairly resistant to most chemicals but I don't know how the pre-glued seams would react to the TSP.
Did you use the TSP to help dissolve the glue on the old floor? I wonder if the TSP had a way of reacting with the seam glue resulting in the powdered seams.
You could contact the manufacturer and explain. They may be interested to what's happening.
1 - 9 of 9 Posts
