interested in the allure trafficmaster planks that are water resilent . have an old vinyl floor and it discolored. i was told ,my floor must be sweating or getting water from slab could i use this
brand
Pro Flooring Installer
Go to search and type in allure. You will find hundreds of pros and cons.
If you have vinyl and the floor is turning dark I would remove the floor. If vinyl discolors from underneth it is most likely mold. This is a bad condithion to cover up. I would take it up, clean the floor with bleach (vintilate while doing this), and seal the floor before putting a new floor down.
