All steel piping, what should I do?
This stuff is to the point where some of the joint are corroding and water leaks spring, should I replaced everything with all copper/pvc? Or is the a cheaper/easier solution?
Copper, Cpvc Or pex.......2 nd question .......no Your pipes are most likley galvanized & are corroded ... You will benefit by replacing
