I was just over at our new construction tonight (a couple months left to the build) and unfortunately noticed what looks to me like a substantial build up of an "orange algae". I cannot tell if this is the "iron bacteria" I've seen online.
This house is on a hill, but we get a good thousand gallons of water/day into the foundation. It's a block construction on footings that were formed with gray rectangular forms that have slits in them, with liberal amounts of gravel on both sides of that. When excavated I saw substantial amounts of sand top few feet, and then a thick, impervious clay.
13 days ago a gravity drain was installed. We also have a sump pit and it will serve as a backup should the gravity ever backup and its check valve kick in.
It looks like algae. It can't possibly be dirt because it holds together in those strands and hangs on to the inside of the gravity drain. The sump pit has a mild swamp smell to it. At the gravity outlet the "what is this" has new brown chunks of what just simply look like algae to me. They seem to wrap around twigs or rocks.
My concern: If this continues at this rate it will eventually clog the footings/gravity drain/sump pit. Is this a reasonable concern?
