I am not familiar with that brand. My my campball Hausfield has a lever by the spray nozzle that rotates the nozzel 180 dgrees to clean it out. when it is rotated it sprays a straight stream. and if the presure is set to high it will lose pressure in that mode as you spray. When it was cleaned last it may have been left in that position. Also depending on what and how well it was cleaned the last time it was used. When I am done with mine and cleaned it with water for water based paint I finish by running mineral spirits thru it. Once i have no residure of paint coming out I spray into the supply bucket of mineral spirits and recirculate the mineral spirits around for 5 minutes or so. Hope this helps
