Hi,
We are renting a large 4 bedroom house in Florida. 1 room is located upstairs and has its own thermostat running on the same system as the rest of the house. We moved in in December. Since it is getting hotter here we are running the AC a lot more and discovered that the house is not receiving even airflow.
All the vents have very low flow of air coming out of them except for the upstairs bedroom and the downstairs hallway vent where the Thermostat is located close to. This vent blows a lot of cold air straight down.
I opened this vent and found multiple open air ducts in it. I will attach labeled pictures. But it looks like none of these ducts are getting any of the blasted air that's coming out.
I decided to do a test and Blocked this vent with a large piece of cardboard. Viola!! all the vents in the house had airflow and the temperature started evening out...........for a few hours. After that the AC kept running and the House temp started raising. I went to check on the upstairs room temp as we had set that thermostat to 82 since it is only used as a guest Bedroom. When I went up there it was at 74 degrees and had all the air flow pumping into that 1 room only. So I ended the test and removed the cardboard.
Everything went back to normal with the uneven temperature in all rooms. I waited for the AC to kick on again so I could see how the air flow worked out of the main vent, and it appeared as though their was 1 main duct pushing air out, 1 sucking air in, where to I don't know and the other ducts were just taking in minimal air.
Can anyone suggest anything I can do to, before calling out a Air Duct company? The landlord is fine with me having someone come out as he has never lived in the hous and has no suggestions, but I usually like to care of things myself when I can.
