Hey,
so here's my problem, i have a 4" floor drain in my basement laundry room and every so often I get a really bad odor from it. When i put my hand over the drain I can feel air pressure coming out of it, so I took off the cover to investigate. The floor drain is trapped so the air isn't coming from the sanitary system, but it does have 5 weeping tile lines coming into it from all directions. I can feel the air pressure coming from these lines, a little bit from each but once it hits the floor drain the pressure builds. My question is how can i prevent this?
If i installed a backflow valve with a rubber seal would this be enough to seal it?
I also noticed that the water in the trap is pure black, i believe the air is agitating this water and creating the smell, any ideas how to clear this up?
Thanks for your help in advance!
