The home is a split level built in 1965 in Ottawa, Canada.
I am planning on air sealing the attic and adding some extra insulation and baffles between the rafters for ventilation.
I've already cutout some extra vents in the plywood soffits and installed these soffit covers I got from HD.
The existing attic insulation is black paper backed (tar product??) fiberglass that is stapled to the joists, therefore no poly VB.
What I plan on doing is:
- Air sealing around any electrical boxes
- Spray foaming (with Great Stuff) the tops of any top plates on interior walls. If I can get to them, I plan on spray foaming the exterior wall top plates too...however its a low pitch roof (see picture) and I think it will be difficult.
- air sealing around the plumbing stack.
- air sealing around any dropped soffits (only 1)
My questions:
1) Should I un-staple the existing paper backed insulation to get to the interior wall partition top plates? I'm not sure I'd be able to re-staple it because its old insulation and its hard to un-staple without tearing.
2) Which way should the fins of the soffit covers point? From the picture I attached it looks like they're pointing TOWARDS to house. I would have thought that they point AWAY from the house.
I've also attached a picture of the house I'll be working on. Notice the low pitch roof. Since the roof is low pitched, installing attic baffles is more than a challenge and since I'm not planning on removing the ceilings from the rooms below, anyone have experience with getting in tight places near where the rafters meet the exterior wall?
thanks,
My questions:
thanks,
