I have a goddman a36-10 air handler just replaced the transformer but don't get no 24 volts output what else can I do. It's a 240 volt system and have power coming to the transfomer. Need help
HVAC / Plumbing
Check the transformer with meter.. Bad transformer to start with ?? Did you burn it up on the install. If you shorted the line voltage you killed the 24 v side. If you short the 24v side you kill the line voltage side
Banned
Check the resistance of each winding.
If they don't read infinity see if you can get ~27vac out of the open-circuited low voltage winding with the primary winding being powered.
It doesn't sound good, so far. If you get another 'former, fuse it before installing.
