Over the last few days I've notice two soccer ball sized and 1 plum sized wet spots on my bedroom ceiling right where the attic air handler is. I went up and noticed the drain basin is dripping right at the drain pipe connection. Not sure why that randomly started dripping but I'll get that fixed.
My issue is, I have blown insulation cellulose and when I lift it up around the spot, the bottom half inch is soaked. There is a plastic covering on top of the sheet rock so it seems only a small amount of water got into the sheet rock.
What are my options?
For the leak, I'm having a HVAC company come to fix that. I put a bucket under it for now.
What do I need to do about the insulation and the sheet rock to make sure it dries and no mold grows? Should I push aside all the dry insulation and remove the wet stuff and then dry the water on the plastic? I'm sure the water has gone in places I can't reach (behind the air handler). Not sure what the best way is to remove all the wet insulation.
Do I need to remove the plastic and let the sheet rock dry?
