1 - 9 of 9 Posts
New to the forum and appreciate any help.
I am installing a full bath in my basement. As seen in pic I have a 4" cast iron vertical waste stack that goes to outside of house and also horizonal under slab along basement wall. I want bathroom to start a couple feet from stack and in this order from stack; Toilet, Sink and Shower. Where in this configuration do I put the Air Admittance Valve? Thanks so much for any advice.
how far away is shower trap from sink.
also what is on the horizontal and vertical stack
The cast iron stack is connected to a full bath on the next floor. The horizontal run from the stack under the slab in the basement is connected to a washer drain and floor drain only. The stack vents to a 3" pipe through the roof. Vent is hard to access and also I dont think it can handle the new full bath in basement.
Thanks!
how far from sink is shower going to be?
Toilet, sink and shower will be in line (next to each other) at just a little more than minimum code requirements.
Thanks
depends on code if you are worried about it. i would put aav under sink and let it be a wet vent for shower and the toilet is fine
Jay,
I am curious why the aav would be at middle fixture as opposed to, say at one end of the branch? I don't do much plumbing so I just dont exactly understand why the sink? Is it because the trap for the sink is the highest trap in the branch?
Thanks for your help!
it would be like running the vent straight up and arming over to catch a shower then continuing up to catch sink with a t then vent going up through roof . also sink is highest fixture . you could put one for shower and then another for sink. toilet is self siphoning so it well drain through vent stack
1 - 9 of 9 Posts
