After top coat, isolated flaws... Quick fix??
2555 Views 27 Replies 6 Participants Last post by  ToolSeeker
After repairing, sanding, priming and finally top coating a ceiling, I notice an area that has minor drywall damage and an area that has a stain showing. Im working on a white ceiling...
My question is can I get away with repairing damage, spot prime just the repaired area and stained area and spot top coat these two areas?
1 - 20 of 28 Posts
Depends on alot of things.
First- what exactly was your finish coat?
How does the light hit the ceiling? Window on the west wall spill across it in the afternoon?
Other light considerations- light and paint is all important.
Shermin Williams Eminence HP Ceiling Paint stock color
There is a window on the West and North, and a fan/light in the center.
I haven't used that paint, but I have heard from those that have that it can be tricky and is not really "flat", which would help your situation.
I would do the repairs, use some BIN on the stains, sand and hit the spots with a roller at least twice with the finish. Feather it out so it has the possibility of blending in, and look at it in different lights.
if it doesn't cut it- will need a full coat.
even then it might be questionable. If it were me i'd use BM Waterborne Ceiling paint or BM's Muresco- but I'm familiar with them and how they work.
I hate to say it but that paint is probably the worse thing they sell
Sherwin
Sherwin
I hate to hear that, why do you think that?
Chris is always good for the details..:laughing:
adrenaline... junky....
I hope you are enjoying our little spat! lol
I think the key is the BIN since there is a stain bleeding thru. But next question, is it an old stain, where did it come from, and has the source been repaired?
Sherwin
I think Im leaning toward not liking SW HP ceiling paint as well. After improving some drywall flaws and covering the stain, I applied a second coat. 1/2 of the ceiling came out acceptable but the other half shows roller marks. I attempted a third coat over the half that looked bad, it improved it but it still looks bad IMO.
SW rep said it couldve been a bad batch so I tried a new batch with the third coat. They also mentioned using their Cashimere or all in one paint. I think Im going to switch to a different paint for the ceiling, any opinions for SW paint?
Use BM Muresco, Ultra Flat Ceiling finish, or at least Super Spec. Merry Christmas all!
PS
and if that offends you, get over it.
Pro Mar 200 in flat
PS
Pro Mar 200 in flat
Im guessing these are not Sherwin Williams paints? I wanted to stick with the Sw lineup, considering their cashmiere or paint primer in one for the ceilings.
Yes the Pro-Mar is a SW paint
Does not have to be a "ceiling paint" any flat paint will do the job.
As c daniels said, promar 200 is SW and cashmiere would be over kill for a ceiling
1 - 20 of 28 Posts
