make sure breaker is wired correctly and eliminate any equipment ground to grounded conductor connections. these can be in any box in the circuit, and could be a ground wire touching the grounded conductor screw of a receptacle. you can have no continuity between grounded conductor and equipment ground. you can disconnect the circuit in the panel and ohm out the problem.
