Main is a Square D
Circuit= garage door opener (motor & 2 led screw in light bulbs) & outside outlets & 2 led 4' shop lights.
I took the gfci outlet out (Cooper) & replaced it with a duplex outlet. Not having a problem, it just was behind a cabinet and a PITA to reset when it tripped. Circuit breaker did not trip under load after the swap.
Took the regular circuit breaker out of the main panel & replaced it with a combination arc fault circuit interrupter ( 20 A QO120cafic).
Now when I plug in the door opener (with or without the bulbs) and/or the shop lights the new combination arc fault in the main panel trips. Plugging either into another circuit (golf cart gfci outlet) will not trip the outlet cfci.
So what's causing the breaker to trip?
Breaker won't trip w/o load.
What am I missing?
Thoughts, please.
Thanks
What am I missing?
Thoughts, please.
Thanks
