I'm pretty sure I know the answer to this, but my google-fu isn't yielding a definite conclusion...
Assuming the panel does not permit double-tapped neutrals...
For single-pole AFCI/GFCI/combo breakers with a pigtail, you should only have one pigtail per bus bar terminal slot, correct? In other words, treat the pigtail as a neutral?
Or is there some kind of allowance to double-tap those pigtails?
Thanks, Chris
Thanks, Chris
