Thanks for looking, this is a little complicated. Basement bathroom reno - licensed plumbers installed PVC replacement for cast iron for entire bathroom, but layout is not very good (was done literally on the back of an envelope after breaking up the floor and discovering the pipes ran a different way which nixed the original design).
The rough in the plumbers left me with is for a sink on the right which only gives 18 inches between the tub and the sink (picture 1 = 2inch pipe on the left of the stack with vent above - sink drain wrapped around back of stack and capped, also vents the tub drain). After reflecting on the envelope design
I want to move the sink over to the left of the room beyond the bath which will give me code clearance around all fixtures - the toilet is behind and to the right of the metal support post (picture 1 = tub drain rough-in on the left in floor, which is connected underground to their sink/vent, see picture 2 for layout).
Based on everything I have read (on this great site) I will need a vent for the sink which will now be on the left beyond the bath, so the plan is to go from the 2inch vent in the joist bay (picture 3) across the room, then over to the new sink respecting the .25inch per foot horizontal drop, then down vertically to the new sink, which will go left horizontally then down to tie in to the bath drain 2inch PVC rough in. The originally planned sink will be capped off permanently.
My questions are:
1) What type of connection must I use to tie in to below the (picture 3) 2inch fernco connector to run a right angle across the joist bay? Sanitary tee or Y? I can lower the existing PVC section connecting to the 2" galvanized vent pipe dropping out of the ceiling by a maximum of 3inches.
2) Should it be a 2x2x1.5inch for the vent across the bay and over at 1.5inch, feeding above the sink?
3) How do I tie in the new sink to the tub drain rough in 2inch pipe (picture 1 on left) bearing in mind that I need to put in a p-trap for a tub drain (will be a clawfoot tub mounted above the dricore subfloor with a knee wall for the plumbing drain access above that hole). Does the sink drain go in front of the tub drain p-trap or after it (where it connects to the 2inch PVC rough in)?
My questions are:
