I've got a fiberglass shower pan in a home built in 1968 and one corner shifts ever so slightly when I'm in the shower. The rest of the pan is solid. Movement is probably 1/16" or so.
I had regrouted the lower half of this shower, and a few months after the repair had a leak reappear. Luckily my son in law was with me when I inspected it and we learned that when I was standing in the shower the lowest run of tile in that corner had cracked free of the wall grout and was floating up and down with the pan. No good.
Anyway - I've pulled all the old tile and plan to regrout without grouting the bottom 1/3 of the tile that overlaps the pan edge.
Two questions:
1. What kind of caulk or sealer should I use on the interface between the tiles and the shower pan to prevent the tiles from being pulled downward again?
2. Maybe should I put a sheet of some thin but durable plastic between the tiles and the pan edge so I can properly grout the edges of the tiles without them getting stuck to the pan?
Two questions:
