Can anyone suggest an elegant solution to the problem in the picture?
I would be just ending the baseboard with a mitered return which would be the same on the other side of the stairs. The only issue is, as you can see from the picture, the baseboard is a bit too high. I'm looking for suggestions on stepping down the baseboard so I can end it.
you can router the same shape the baseboard has on top, just notch the baseboard with a rounded cut instead of square and follow it around with the router to drop that last few inches..
not seeing the piece before hand, I didnt know how big the shaped top was...why dont you just cut an inch or 2 off the bottom and miter the ends and call it good?
Yah, it is somewhat elaborate. The problem with cutting off an inch is that it would look odd compared to the other side of the stairs. Also, as it comes around the corner, it is a long run around an entire 400sq foot room. I'd have to trim the entire run...
I've got a couple of different solutions in case anyone is interested. I got these ideas from another forum. I whipped this up as a test. It seems ok.
Another great idea was to separate the two sizes of baseboard with a thinker block that is slightly taller than the tall piece of baseboard. That way both pieces kind of die into the block i.e. I think it's called a plinth block. Either way, I would just do both sides of the stairs and call it a design "feature"
Sure will. Let me work on the finished one. Although Im still contemplating using a a plain block instead so if I don't use the "dropped miter" idea, it's really just three pieces. The left piece is just a 45 all the way from top to bottom. The right piece is also just a 45 from top to bottom. The middle piece is two 45's and is basically as wide as the drop I desire. It was about 3/4". I then glued, filled and painted making sure to hide the cut lines as much as possible...
I think the stepped down miter example looks great. I'm not a big fan of a transition block. Most of the time, even though you decorate them, they still look like an afterthought. And you said you were going to return the left end, that would be my choice.
Mike Hawkins:smile:
...and, by the way, I have to credit Tom Ewell over at the SawmillCreek forums for the dropped miter idea. I'm not that ingenious to figure that one out...
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
DIY Home Improvement Forum
