some of you may remember me previous post about my "rats nest" breaker panel. I'm starting to get ready for running the new wires and mounting the new subpanel inside the house and I need some help with how this will all tap in to the existing breaker panel. Here's how it looked when I first started...
...and here's how it looks now that I've done a bit of cleanup with a vacuum
There's a TON of nesting still up inside and behind the meter and I'm probably going to have the power company come and clean that out for me as I don't think I'm allowed behind there...
So here's my plan: I'm going to run a new heavy line from this panel to a new subpanel inside my house and slowly begin running new circuits out to each room as we remodel them. This way, I'm running new electrical while keeping the old in place -abandoning circuits one at a time. Eventually, there will be no live circuits on the original panel -just the meter.
Here's a shot from the inside of the house (back of the panel):
So here's some of my concerns: I'm not sure where I'd tap into the existing power feed. Would I need to access the wiring behind the meter as opposed to the two large black leads in the center of the existing breaker panel? If I need to go behind the meter, maybe I'll have the power shut off at the pole by Edison and then have them go in and clean out the back of the meter (all the old rat's nest bedding) and run new power leads at the same time before they switch it back on?
Any ideas would be great!
