I have a knack of causing my own problems.* we have this 'wind vane' gadget we bought at a flower show.
I've replaced the bearings a few times over the years.
This last time, I was pushing the bearing out and (my mistake) not using something with the diameter to push on the outer ring of the bearing.* The inner ring, balls, etc came out.* And now i have that outer ring stuck in there.* I tried prying it out / getting under it from the back but there's not enough room.
I guess I need a gadget that expands a bit to grab the inner surface and then pull that out?
Do you know what that looks like / is called?
The picture is a new bearing and my hand (to give size perspective) and the race with the outer part of the old bearing stuck in there.
Thanks!
Thanks!
