Everyone --
First I want to apologize if this has been addressed before or if I use the wrong terminology. Plumbing is not my strongest point.
It seems that whenever I need to clean out a drain, or otherwise need to replace the drain clean-out cover, I have all sorts of problems. Even when I am extra careful taking the cover off, it often is virtually impossible to get back on.
First is the issue that I am talking about cast-iron clean-outs that are often all rusty. Even the brass caps are hard to get started some times. Secondly is the fact that the edges of the cast iron pipe seems to get damaged, which makes it even harder to get the cap started correctly. Third is the fact that these caps are often located in almost inaccessible locations and are oriented in odd angles, so the exact angle to attempt to restore the cap is not always obvious to me. Lastly, the cleanouts seem to use a rather fine thread, which makes it harder to get it started right and which I have not even seen a tap for and probably could not afford anyway.
More modern systems with PVC do not present these problems, only the older, cast-iron based drains.
Does anyone have any suggestions that might help and make the re-installation of the caps easier of someone who only opens a drain once every year or two?
Thank you all!
Thank you all!
