it still amazes me how any contractor could use nails instead of drywall screws anymore. The cost difference is so minimal and there are so many good tools on the market that speed along the installation of dw screws. Partially frustrated because I've been going through the same thing in my house, but the house I just bought is 10 years old so I have no recourse - but even ten years ago they knew better than to use nails..
In any case, if your builder is willing to work with you that is greeat, you may want to check with your lawyer and check your contract as well...this could get pretty expensive for your builder. I don't see any reason to replace the drywall, but the right thing to do is start pulling out those popped nails and putting screws in instead. You could put a screw in the same hole if you like, but I would advise putting a screw an inch or so away as well. Compound over the nail holes and screws - couple of coats - prime and paint. How much of this your builder is willing to do is beyond me - but this is a lot of time consuming annoying work - which generally means expensive. Is your house painted already? If so this pretty much means you repainting the entire house if the nail pops are that bad.
