1 - 8 of 8 Posts
I am a computer nerd and run quite a few commercial-grade bits of hardware, including several rack-mounted computer servers. I mention this as a precursor, to show why I'm looking at fiber optics.
I am in the process of buying a new house. It is part of a tract-home project, so not a custom-built home. On Friday (01/03/2020), we had a pre-drywall frame walk-through, going over electrical and all the stuff that will be covered up with drywall, so we know what is where when working on home improvement projects down the road. There are a few interesting details to this new home. First, the house is a two-story home, but the second floor makes up only about the middle 1/3rd of the footprint from front-to-rear with a roof that peaks directly above the middle of the second floor, with one facet facing the front and the other facing the rear of the house. This creates a very large attic space in the front and rear of the house; I refer to them as the front and rear attics.
Another interesting detail of the house is that in addition to a 2-car and 1-car attached garages, there is a detached garage that is 15-feet wide by 24-feet deep by 9-foot tall open space, with attic. I do not plan on using this detached garage as a place to park a vehicle, but rather it will be my "computer lab" or "man-cave." I am having this building insulated and will be adding a ductless mini-split for temperature management. This building has an electrical sub-panel and a 2" conduit with a very hefty non-metallic sheathed bundle of electrical wires running from the attached garage to the detached garage. Originally, I was planning on putting in a conduit coming out of the rear attic of the house, down the side of the house, under the ground to the detached and then up and through the wall of the detached garage. The project manager gave me an idea I immediately shot down, which was running CAT6 cable through that 2" conduit running with the electrical wires. I shot it down due to inductive interference running data cables parallel with AC electrical wires.
Overnight, I was thinking more about this and came up with a possible solution... I wanted to have high-bandwidth linking of the two structures and adding my own conduit that runs down the side of the house and holes through the walls were not that appealing. I then realized that if I ran fiber optic lines, I could run that through that 2" conduit before the Monday start to drywalling. The only place open over the weekend that sold bulk fiber optic cabling had ONE box fiber optic cabling. It was 1000 feet of 62.5/125µm, OM1, twin zip line. If time and money were no object, I may have gone with something better, but from my very quick research, it appears I should be able to run 10GBASE-SR, up to 33 meters (~85 feet) over this. I decided to purchase this fiber optic cable and went to the new house to install it. My plan is to put a network switch in the detached garage, and one in each of the attic spaces that have SFP+ ports for linking switches. I ended up running fiber to each of the locations I plan on installing the switches, plus a few additional locations for future needs. The longest runs of fiber are no more than 50 feet.
As I was very limited on timing to placing this fiber, I didn't research exactly how to terminate the fiber, as that will not be needed until we move into the house, in April. Now that it is in, I'm starting the process for figuring out how exactly I will terminate the fiber. I have seen that there are several different ways to terminate them, based on the equipment and experience of the technician. I've seen that there is epoxy/polishing, which appears to be the highest quality if done properly. There is also the pre-polished/no epoxy type connectors. This appears to be easier but more costly and also prone to other issues. I am debating whether I should buy equipment for terminating the fiber and do it myself or to hire someone to come to the house to terminate the fiber.
I am hoping that someone with experience here has any experience in running fiber through a house and whether to purchase the equipment needed to terminate the fiber or find someone that does it all the time to come with their equipment and experience to do the work for me.
I will need two LC-type connectors on each end of the zipline. There is one from the run between the detached garage to the front attic space. Then there is another from the front attic to the rear attic; I ran CAT6A along-side this run. Inside our master bedroom walk-in closet, there is a 30" tall panel (Legrand On-Q ENP3050) where all the CAT5 cable, coax and alarm cable the builder installed is run. The builder ran a couple CAT5e cables between this panel and the demarcation location. I plan on putting a small gigabit network switch in this panel, as well as my router. I also added a run of CAT6A and fiber from this panel and the rear attic location for a network switch. Lastly, I ran fiber from the demarcation location to this panel. This last fiber will likely NOT be needed for quite some time, but easier to add now.
The ISP provides fiber to the house, currently at 1 Gbps. My brother's ISP just announced an option for 6Gbps data, so I may need something better than CAT5e in the future. For my router, it is a home-built router, using a mini-ITX motherboard running pfSense. My current motherboard has four 1Gbps RJ45 ports but Jetway (the maker of my current motherboard) now makes a similar motherboard with four SFP+ ports I could upgrade to, to handle higher speeds in the future. I will likely start by connecting the router to the small switch in the closet via a short patch cable and connect the rear attic switch to this small switch via the CAT6A I just ran yesterday. This will be the primary bottleneck in the system but it should be fine for a while.
I would have just run conduit and pulled in the fiber later. Conduit should be installed so that you have access to pull points at any time after the construction is finished.
There was no ability to put a conduit within a conduit to the detached garage. While there was some room around the electrical wires inside the 2" conduit, it was difficult to get the fish tape through the last upwards bend in the 2" conduit as it was. This particular run is why I decided to do fiber in the first place. Everywhere else throughout the house I could have just managed with CAT6A wiring. I added the other lengths of fiber because I had already purchased a 1000' spool, so why not? This was all so I wouldn't have to run a visible conduit down the outside of the house, across a buried trench and up into the building about 8 feet away.
If the terminating proves too daunting the shielded cat 6a with foil protecting would almost certainly carry 10gbps in that environment. But, the computer geek in me would rather have the fiber too :)
Sent from my Pixel 4 XL using Tapatalk
· Master Electrician
A little late to the game here, but I would just call a company that has the tools to do the fibre terminating. The cleave is the most expensive and the most important part of the termination. If you do not have a good cleave, it does not matter about anything else.
A good quality cleave is generally outside the typical DIY price range for something they will only use once.
Cheers
John
I know that you can accomplish it in two possible ways. It is possible to do it with connectors that can mate two fibers to create a temporary joint. The second option is the connection of the fiber to a piece of network gear or with splices which create a permanent joint between the fibers. I think the first variant is more practical. There are various types of connector fiber types. But the main issue I have displayed above. And please, remember that this process is not a place to experiment or learn! It'll cost you big time! If you are doubtful, you would better apply to a fiber optic construction manufacturer such as this one. Have a great day!
· Challenge Everything!
Late to the party, as always.
We just did some Fiber runs in my Home, actually from my Garage (Computer Lab) to the House, 175 feet to be exact.
We used a Fiber optics Fusion Splicer, such as this one here:
My Neighbor works for AT&T and we were lucky enough to have the Splicer "borrowed" over the weekend.
It is more complicated than it looks, and it all worked out.
As another option, you could run Cat7 or Cat8, they give you also a tremendous Speed (10 GB/s) but as always, CAT7 or Cat8 is limited to just 300 feet.
Fiber isn't.
1 - 8 of 8 Posts
