I have two HVAC units, one for upstairs and one for downstairs. They work well and both are controlled by programmable thermostats. I do have one slight problem and that is the air in the bedroom gets a little too humid. This occurs in the wee hours of the morning. The quick fix (when it awakens me) is to turn on the upstairs blower for a couple of minutes to replace the air in the room with air from other parts of the upstairs region of the house.
The thermostats are programmed to lower the temperature in the house by a couple of degrees F just before bedtime. If I were able to put some sort of timer on the upstairs blower motor to run it for a couple of minutes every hour or two, it would solve the problem.
Is there any device that I can purchase that would start and stop the blower at predetermined intervals. I'm thinking about an ordinary timer and wiring it to the blower using the power supplied to the unit itself.
